Need NAT commands (Urgent)
Answered Question
Dec 18th, 2008
how can i config nat in router..using "Only WAN" ip.ISP has blocked entire /28 lan ip due to some span issue....for time being thought of using wan ip for NATing ... can some one help me in configuring the same ...would be very much appreciated ...
thanks in advance
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
Hello Bharthi,
nat translations entries are created based on a traffic
with a PC on net 192.168.0.x try to navigate over the internet
Hope to help
Giuseppe
Correct Answer by John Blakley about 8 years 7 months ago
You're missing "ip nat out" on your serial interface.
That should fix it.
HTH,
John
*please rate if helpful*
Overall Rating: 3.7 (3 ratings)
Giuseppe Larosa Thu, 12/18/2008 - 06:34
  • Hall of Fame,
    Founding Member
Hello Bharti,
you need to define the lan interface as NAT inside
the wan as nat outside
int f0/0
desc lan
ip nat inside
ip address 10.10.10.1 255.255.255.0
int s0/0
desc wan
ip nat outside
ip address xx.xx.xx.2 255.255.255.252
access-list 11 permit 10.10.10.0 0.0.0.255
ip nat inside source list 11 interface s0/0 overload
the overload keyword allows for PAT
this is enough for basic nat to access the internet
use sh ip nat translations to see the activity of NAT
note:
if you have also advanced requirements like an ipsec tunnel to another site some more tuning is needed
Hope to help
Giuseppe
bagvanliju Thu, 12/18/2008 - 06:59
Hi Gui,
Thanks for the update ..i ve done the same config but not able to see any nat transaction ...also see the router config below
XX#s run
memory-size iomem 25
ip subnet-zero
ip name-server XX.XX.XX.XX
class-map match-all VOICE_PUBLIC
match access-group 112
class-map match-any SMTP_CLASS
match access-group 111
class-map match-any REST_ClASS
match any
class-map match-any VOICE_CLASS
match ip precedence 5
policy-map MOD_QOSPOLICY
class VOICE_CLASS
bandwidth percent 20
class SMTP_CLASS
class VOICE_PUBLIC
bandwidth percent 5
class REST_ClASS
bandwidth percent 30
interface FastEthernet0/0
ip address 192.168.0.1 255.255.255.0
ip nat inside
speed auto
interface BRI0/0
no ip address
shutdown
interface Serial1/0
ip address XX.XX.XX.XX 255.255.255.252
service-policy output MOD_QOSPOLICY
ip nat inside source list 11 interface Serial1/0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1/0
no ip http server
access-list 11 permit 192.168.0.0 0.0.0.255
snmp-server community modely RO
modelytics#s ip nat tran
XX#
Correct Answer
John Blakley Thu, 12/18/2008 - 07:02
  • Purple, 4500 points or more
That should fix it.
HTH,
John
bagvanliju Thu, 12/18/2008 - 07:07
Thanks for the hlp it was my misatake ..changed the same but still not showing the same
ip nat inside
speed auto
interface Serial1/0
ip nat outside
ip classless
no ip http server
modelytics#
modelytics#
modelytics#
modelytics#
modelytics#
Lijesh.N.C
Correct Answer
Giuseppe Larosa Thu, 12/18/2008 - 07:11
  • Hall of Fame,
    Founding Member
Hello Bharthi,
Hope to help
Giuseppe
bagvanliju Thu, 12/18/2008 - 07:24
Thanks gui its working thans for the valuable supprt ...
Lijesh.Nc
bagvanliju Thu, 12/18/2008 - 07:25
Thanks J its working thans for the valuable supprt ...Thanks for poiting the mistake ..i ve rated ..
Lijesh.Nc
John Blakley Thu, 12/18/2008 - 06:35
Example:
int fa0/0
ip address
ip nat out
int fa0/1
ip address 10.1.0.1 255.255.255.0 (private ip)
ip nat in
ip nat inside source list 1 inter fa0/0 overload
access-list 1 permit 10.1.0.0 0.0.0.255
HTH,
John
