router 2600 link
Dec 18th, 2008
I have wireless link from my ISP for internet. When I attach my system with demarc I get the internet. But I want to set up my cisco 2600 router first with demarc. router only have 2 ports: 1.ethernet 2.serial. I have 5 public IP's provided by my ISP. How can I set my router and then the other LAN devices ? any advice. Thanks. Tahir
viyuan700 Thu, 12/18/2008 - 16:01
what kind of interface does your demarc have?
Is this 2612 with only one ethernet port?
That serial is something like VWIC-1MFT-T1/E1 card with RJ45 connector?
tahir1234 Sat, 12/20/2008 - 06:37
I plug RJ-45 Ethernet cable with demark to router ethernet. But 2612 router have only one ethernet on it. I think serial is 60-pin standard. Please help. Thanks
viyuan700 Sat, 12/20/2008 - 09:38
This link tells about the 60 pin serial cable.
You can buy a 60 pin to EIA/TIA-449, -530, -530A, V.35, and X.21 Distance cable(these cable are good ) cable and then one more cable which converts to RJ45.
Or if speed is less and distance is not much then can take a 60 pin serail to EIA/TIA-232 Distance and then there are so many cables which convert from 232 to RJ 45.
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/ConntSer.html
Consult your cable dealer/ cisco dealer if this kind of solution work or if anybody on this board have idea about it.
