How do I configure it so I can Hit a Wan ip address from My Lan?
Dec 18th, 2008
Namely, I want to be able to use the wan IP address for MY Terminal Server, WSUS Server, etc from both My LAN users and WAN users.
I should mention that I am using a Cisco 1811 and SDM Version 2.41
John Blakley Thu, 12/18/2008 - 07:45
  • Purple, 4500 points or more
If you're wanting someone to come into your network to use your TS, you'll need to configure static nat and map your public IP to a private address on the inside.
HTH,
John
dallas590 Thu, 12/18/2008 - 07:55
I can already hit them all from the outside, and have this set up.
I want to be able to hit my servers on my 192.168.1.*, using their Wan addresses 205.*.*.20 from on the LAN (192.168.1.*).
Something to tell my internal network machines that the wan address given should be redirected to in-house.
John Blakley Thu, 12/18/2008 - 07:59
I'm not sure this will be possible, but I've never had to configure it.
John
