Extension Mobility Agents Getting - "Device is Restricted" Msg
Dec 18th, 2008
We upgraded a customer last night to CM 6.x and UCCX 5.0(2), that all seemed to go fine.
Today the agents that use Extension Mobility, and then try to log in to CAD are getting a message at login that states "Device is restricted.".
Phone agents and non Extension Mobility agents log in just fine.
I have never seen this error message before. Does anyone have an idea as to what may be happening here?
Dan
Overall Rating: 5 (1 ratings)
mikram Thu, 12/18/2008 - 08:33
Could you pls confirm that services are running fine and referring to right CUCM server. Also, check for EM parameters on device profile for user.
d.gavin Thu, 12/18/2008 - 08:50
All EM services are running fine on Pub and Sub.
The agents can log into EM just fine. The error occurs when they launch CAD, after a few seconds it pops a small error window that says "Device is restricted"
Marwan ALshawi Sun, 02/22/2009 - 02:42
hi guys
have you got this issue resolved ?
because i have the same error message with on of IPCC agents
while when i loged in in the same phone using another user details worked fine
i am sure the seting is correct identical to all other working IPCC agents
i wish you have got a workaroung to this error message
thank you
Hythim Ali El Hadad Sun, 02/22/2009 - 06:36
Hi Gavin,
Kindly check the Allow Control of Device from CTI checkbox to be checked in the Default Device Profile Configuration window in the Unified CM
Wish this be helpful
Best Regards
