Incoming Call Routing
Dec 18th, 2008
Hi all,
I'm facing an issue at a customer site and dunno how to solve it.
Maybe someone could help.
My customer is running UC520 with 1 E1 card and 1 BRI with. Each card for 2 differents customers.
So my E1 for Cust1 and the BRI for Cust2.
My issue is related to incoming call. Both customer would like to translate extension '1' to an ephone-dn.
But how can I do to say "Ok, when someone will call the PRI with extension 1, it will be directed to XXX, but when someone will call the BRI with extension 1, it will be directed to YYY.
Here is my config, but it doesn't work at all.
voice translation-rule 10
rule 1 /^1$/ /311/
voice translation-rule 15
rule 1 /^1$/ /211/
voice translation-profile Cust1
translate called 10
voice translation-profile Cust2
translate called 15
voice-port 0/2/0:15
cptone LU
compand-type a-law
timeouts interdigit 2
bearer-cap Speech
voice-port 0/1/0
cptone LU
compand-type a-law
bearer-cap Speech
dial-peer voice 200 pots
corlist outgoing callBT
description ** E1 Outgoing/Incoming CUST1 **
translation-profile incoming Cust1
destination-pattern 0T
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
incoming called-number .T
direct-inward-dial
port 0/2/0:15
dial-peer voice 100 pots
corlist outgoing callRadianz
description ** BRI Outgoing/Incoming CUST2 **
translation-profile incoming Cust2
destination-pattern 0.T
progress_ind setup enable 3
direct-inward-dial
port 0/1/0
Some help would be greatly appreciated :)
Fabian
iptuser55 Thu, 12/18/2008 - 09:50
How many digits does your Telco send? From the translation pattern it looks for only a complete match on teh digit 1. It may be better to change it to rule to /^1../ /211/ if they send you 3 digits
f.giordano Thu, 12/18/2008 - 09:59
hi,
My telco send the necessary digit. It's not the issue. The pb is that sometime it translate 1 to 211, and sometime to 311...
Fabian
Brandon Buffin Thu, 12/18/2008 - 10:21
Fabian,
Try the following.
1. Remove the translation profile from dial peers 100 and 200.
2. Modify the "incoming called-number" command on these dial peers to be "incoming called-number ."
3. Apply the translation profiles to the voice ports:
voice-port 0/2/0:15
voice-port 0/1/0
Hope this helps.
Brandon
f.giordano Thu, 12/18/2008 - 13:22
Hi Brandon,
Thx for your answer. I'll try it tomorrow.
I keep u informed.
Fabian
