Adding a new provider connection to a 7513 router.. routing questions.
Dec 18th, 2008
Hello all!
I have a 7513 that has a single FastE circuit and of course a single default route for traffic. I am adding another FastE circuit from another provider and they have provided the /30 WAN and a /24 for LAN.
What I am trying to do seems pretty simple but for some reason it is just eluding me.
What I want to do is route out the /24 IP space the 2nd provider has given me out their interface.
Example:
I have the subnet 172.126.120.0/23 routing out the default connection.
I need to route the new LAN 172.200.1.0/24 out the /30 interface 175.100.0.105.
Right now the traffic on the LAN side routes out through the firewall and once it hits the router it is being sent out the default GW even when I add a route like..
ip route 172.200.0.0 255.255.255.0 175.100.0.105
How would I do this?
Thanks!
Jon Marshall Thu, 12/18/2008 - 09:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Kevin
PBR (Policy Based Routing)
access-list 101 permit ip 172.200.1.0 0.0.0.255 any
route-map PNAT permit 10
match ip address 101
set ip next-hop 175.100.0.105
where 105 is the ISP address. If 105 is the ip address on your interface then it will be 106 which will be the ISP interface.
then on the LAN interface that connects to 172.200.1.0
int fa0/1
ip policy route-map PNAT
Jon
kevin_spies Thu, 12/18/2008 - 12:34
I will give that a shot, I will let you know how it goes.
sachinraja Thu, 12/18/2008 - 13:24
  • Red, 2250 points or more
Kevin
Let me complicate things :) Jon's response is precise and exact to your requirement.. but do you need service provider redundancy :) automatic fallbacks and stuffs like that ??
Raj
