Manipulate Outbound for Subnet
Dec 18th, 2008
Folks,
I have a multihomed multi-tenant BGP environment that I would like to manipulate outbound traffic based on source IP address. Is there anyway other than PBR to accomplish this?
Thanks!
Lehi
Richard Burts Thu, 12/18/2008 - 12:19
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Lehi
I can not think of a good alternative for manipulating outbound traffic based on source address other than PBR.
Rick
lxcollin1 Mon, 12/22/2008 - 15:53
Hi Rick,
Thanks for your response. If PBR is the only solution, what kind of performance hit will I take if I enable PBR on my DFC enabled Cat6k?
Lehi
Richard Burts Tue, 12/23/2008 - 04:48
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Lehi
The impact of implementing PBR may vary depending on how complex your PBR route map is, the amount of traffic that it processes, and what else is running on your Cat6k. But I would expect the impact to be pretty small.
Rick
Jon Marshall Tue, 12/23/2008 - 05:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Lehi
As Rick says it does depend on how complex your PBR setup is. PBR is supported in hardware on the 6500 but there are restrictions and you should be aware of these -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/layer3.html#wp1027016
Jon
