h323 terminal calls fails randomly to ip phone (skinny)
Dec 18th, 2008
i have a cluster of 6 nodes (cucm 6.1) and gk's in a cluster and h323 video terminals and ip phones + cvta.
when dialing from h323 terminal to skinny terminal call fails randomly.
i found that calls are directed by the GK to CUCM cluster using more then one node. if the call is directed from h323 terminal to the NODE with registered dialed ip phone everything is fine.
any idea, what is wrong?
Anonymous (not verified) Fri, 12/26/2008 - 06:27
From the gatekeeper please send show run/show version.
Is the Skinny Endpoint and H.323 Endpoint registered with CCM?
a.klessa Sat, 12/27/2008 - 05:22
hi,
well, i think have found the issue. the thing is that there are 2 RASagg registered to that GK for my 12 h323 endpoints. h323 endpoint were using different DP in CUCM.
i am going to test it asap.
best
aleksander
