Upgrade to 6.1.3
Dec 18th, 2008
  • Bronze, 100 points or more
Has anyone upgraded to 6.1.3? Is 6.1.3 a cumulative of all bug fixes in the 6.1.1 and 6.1.2 train?
Please let me know your thoughts on whether or not 6.1.3 will be a stable release. Any help appreciated. Tahnks
Jason
David Hailey Mon, 01/26/2009 - 20:11
  • Purple, 4500 points or more
6.1(3) has some very important fixes in it and it is expected to be a stable release. I have already upgraded a lower environment system for one client to 6.1(3) on the release date and have not had any issues thus far.
webstd.design Tue, 01/27/2009 - 05:10
But what about if you want to upgrade 6.1.3 system to 7. What should you do then?
Should Cisco implement upgrade from 6.1.3 to 7? Can anybody answer me this question?
gogasca Mon, 01/26/2009 - 23:39
  • Green, 3000 points or more
Hi Jason,
Yes 6.1.3 includes cumulative fixes for 6.1.2
prety stable I would say.
LeeSnyder_2 Tue, 01/27/2009 - 01:10
Point to note, You can not upgrade to V7 currently from 6.3, only 6.2 so if you are planning an upgrade may not be worth it as I had to downgrade prior to upgrade.
robray_sc Wed, 02/11/2009 - 10:19
How did you downgrade from 6.1.3? Its not letting me load the 6.1.2 version so I can upgrade to 7.0(2).
Did you just start from scratch and load 6.1.2.
webstd.design Wed, 02/11/2009 - 13:54
Hello, robray
I didn't clearly understood you post.
You want to say that there will be issues if I want to upgrade from CUCM from 6.1.3 to CUCM 7 by first downgrade from 6.1.3 to 6.1.2?
LeeSnyder_2 Wed, 02/11/2009 - 14:13
With 7.0(2) it does say you can upgrade from anything above 6.0(1a) so the issue upgrading from 6.1.3 may now be resolved.
When you attempt the upgrade which I did via FTP it did say unsupported but that was to 7.0(1). As I had upgraded from 6.1.2 to 6.1.3 I was able to swap the active partitions back to 6.1.2 to upgrade to 7.0(1).
webstd.design Thu, 02/12/2009 - 12:21
What should I do If I wanted to upgrade from 6.1.3 to 7? Will Cisco implemetn solution to direct upgrade or it will be possible only after downgrade?
Jonathan Schulenberg Thu, 02/12/2009 - 17:14
  • Cisco Designated VIP,
    2017 IP Telephony
UCM 6.1(3) was released after UCM 7.0(1). Because of this, a direct upgrade is not possible. We expect the next release of UCM 7.x to support a direct upgrade. Whether they decide to release 7.0(3) or move directly to 7.1 has not been decided at this point.
Chris Deren Sat, 02/14/2009 - 09:14
  • Hall of Fame,
    2017 IP Telephony, Contact Center, Unified Communications
You will need to wait for CM 7.1 if you want to upgrade from 6.1.3, 7.1 is just around the corner though.
HTH,
Chris
