ISDN Messages
Answered Question
Dec 18th, 2008
Hi Expert's
someone know how to turn off the next ISDN messages from terminal monitor:
VoIP-GW-02# terminal monitor
VoIP-GW-02#
110000: Dec 18 20:24:52.255: %ISDN-6-CONNECT: Interface Serial0/1/1:1 is now connected to 22904270 N/A
110001: Dec 18 20:24:52.879: %ISDN-6-CONNECT: Interface Serial0/1/1:30 is now connected to 22730911 N/A
110002: Dec 18 20:24:55.219: %ISDN-6-DISCONNECT: Interface Serial0/1/1:30 disconnected from 22730911 , call lasted 2 seconds
Correct Answer by Jesse Drohen about 8 years 7 months ago
Configure "no logging event link-status" under the interface.
GW01#config t
GW01(config)#interface serial 0/1/1:23
GW01(config-if)#no logging event link-status
hth,
Jesse
Overall Rating: 3.5 (2 ratings)
Nicholas Matthews Thu, 12/18/2008 - 20:24
  • Red, 2250 points or more
I believe this is a aaa command.
I would do a sh run | i aaa
I believe it is aaa gw-accounting or something similar.
abrenes26 Fri, 12/19/2008 - 07:12
Hi nicmatth
This is the result of the sh run| i aaa
VoIP-GW-02#sh run | i aaa
aaa new-model
aaa authentication login LocalDB local
aaa authentication login ACS group radius local
aaa session-id common
Do you see something?
Correct Answer
Jesse Drohen Fri, 12/19/2008 - 08:17
  • Cisco Employee,
GW01#config t
hth,
Jesse
