Cisco Unified Communications Manager CDR Analysis and Reporting
Dec 18th, 2008
I currently need to be able to figure out the Long Distance usages of certain group/department within our company. Currently this group in our Cisco phone system. I found that we have Cisco Unified Communications Manager CDR Analysis and Reporting in CallManager. I would like to utilize it. I am able to pull the Traffic summary of certain extensions but the report only shows the internal and incoming traffics not the Local/LD/International which I need it. For Local/LD/International, they are showing 0 calls which are not right.
I pulled it from “System Reports >> Traffic >> Summary by Extensions” in Cisco Unified Communications Manager CDR Analysis and Reporting.
Anyone have any idea how to pull the CRD reports so we can know the LD usage for certain exts. in CallManager or any other application that is provided as part of the Cisco Unified Communications?
We are using CUCM 6.1
Thank you
Overall Rating: 5 (2 ratings)
Jaime Valencia Thu, 12/18/2008 - 14:06
  • Cisco Employee,
  • Hall of Fame,
    2011
have you already configured the dial plan on CDR so it tags the call accurately??? if not you need to do so if you plan to use it for that
java
if this helps, please rate
sienz.sienz Thu, 12/18/2008 - 14:14
Is the any manual/guide on how to configure the dial plan on CDR so it tags the call accurately?
I would like to utilize this CUC feature.
sienz.sienz Thu, 12/18/2008 - 15:28
Where can i find?
System > System Parameters > Mail Parameters.
System > System Parameters > Dial Plan Configuration.
sienz.sienz Thu, 12/18/2008 - 15:29
Sorry, i got it.
I was trying to find it in the System-Service paramenters.
If I make changes in this system parameter, is it going to effect the CallManager or only the CUCM CDR Analysis and Reporting?
For example: If I make changes the Dial Plan Configuration in CDR, will it effect the CallManager Dial Plan?
Jaime Valencia Thu, 12/18/2008 - 16:59
  • Cisco Employee,
  • Hall of Fame,
    2011
no, only to CDR to recognize the calls. it does not affect at all anything in CUCM dial plan
be aware that as many changes only calls made AFTER the change will be tagged
java
