Extended the greeting time!!
Rob Huffman Thu, 12/18/2008 - 15:54
Hi Ken,
This can be changed :) My understanding is that the Greeting Length for a Call Handler is determined by the COS of the person recording the Greeting. Have a look;
Class of Service Greetings Settings
The class of service greetings setting specifies the maximum length of greetings.
Subscribers > Class of Service > Greetings Page
Field Considerations
Maximum Greeting Length in Seconds
Select the recording length allowed to subscribers assigned to this COS for recording greetings.
The range is 1 to 999 seconds; the default is 90 seconds.
If enabled, a warning tone will sound before the maximum greeting length is reached.
Hope this helps!
Rob
Rob Huffman Fri, 12/19/2008 - 05:42
Hi Ken,
Unity should not need to be reset here. I have never seen this not work ?? Is the Subscriber the owner of this Call Handler? Can this subscriber record a personal greeting longer than 90 seconds? It almost sounds as if this change to the COS didn't save properly.
Let us know,
Rob
Rob Huffman Mon, 01/19/2009 - 06:34
Hi Ken,
Nice troubleshooting here! +5 points for this kind follow-up and in sharing your resolution to this issue.
Cheers!
Rob
