HWIC-4ESW not recognized by 2821 router
Dec 18th, 2008
We recently installed an HWIC-4ESW module in a 2821 router. The module shows up in "show inventory" and it shows us in "show diag" but the additional FastE ports do NOT show up in "show running-config". IOS is c2800nm-ipbase-mz.124-3i.bin.
Has anyone seen this before?
Is there a fix or is the module bad?
Gary-Brown Fri, 12/19/2008 - 07:25
Yep, checked the pre-requisites. It's the only HWIC installed and we even tried changing slots.
We have another 2821, same boot code, same IOS and it works fine.
ajagadee Fri, 12/19/2008 - 08:21
  • Cisco Employee,
Gary,
Can you post the outputs of "show diag" and "show inven".
Arul
Gary-Brown Fri, 12/19/2008 - 09:56
#sh inv
NAME: "2821 chassis", DESCR: "2821 chassis, Hw Serial#: FHK1220F0CS, Hw Revision: 52.57"
PID: CISCO2821 , VID: V04 , SN: FHK1220F0CS
NAME: "4 Port FE Switch", DESCR: "4 Port FE Switch"
PID: HWIC-4ESW , VID: V01 , SN: FOC11223L36
NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T= , VID: 1.0, SN: 35817651
#sh diag
Slot 0:
C2821 Motherboard with 2GE and integrated VPN Port adapter, 2 ports
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
PCB Serial Number : FOC12191PDB
Hardware Revision : 1.0
Top Assy. Part Number : 800-26921-03
Board Revision : A0
Deviation Number : 0
Fab Version : 03
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 87
Hardware date code : 20080507
Chassis Serial Number : FHK1220F0CS
Chassis MAC Address : 0021.55dc.fb20
MAC Address block size : 32
CLEI Code : COM7M00ARA
Product (FRU) Number : CISCO2821
Part Number : 73-8853-05
Version Identifier : V04
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 32 31 39 31 50 44 42 40
0x10: 03 E8 41 01 00 C0 46 03 20 00 69 29 03 42 41 30
0x20: 88 00 00 00 00 02 03 03 00 81 00 00 00 00 04 00
0x30: 09 87 83 01 32 67 7B C2 8B 46 48 4B 31 32 32 30
0x40: 46 30 43 53 C3 06 00 21 55 DC FB 20 43 00 20 C6
0x50: 8A 43 4F 4D 37 4D 30 30 41 52 41 CB 8F 43 49 53
0x60: 43 4F 32 38 32 31 20 20 20 20 20 20 82 49 22 95
0x70: 05 89 56 30 34 20 D9 02 40 C1 FF FF FF FF FF FF
WIC Slot 1:
4 Port FE Switch
Base MAC Address : 001b.54f0.3aa8
MAC Address block size : 4
PCB Serial Number : FOC11223L36
Hardware Revision : 6.0
Part Number : 73-8474-06
Board Revision : A0
Top Assy. Part Number : 800-24193-02
Fab Version : 05
CLEI Code : IPUIA00RAA
RMA History : 00
Product (FRU) Number : PA-A3-OC3SMI=
Version Identifier : V01
Connector Type : 01
0x00: 04 FF CF 06 00 1B 54 F0 3A A8 43 00 04 C1 8B 46
0x10: 4F 43 31 31 32 32 33 4C 33 36 40 00 56 41 06 00
0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Could not get Card instance pa_bay = 0 slot = 1
WIC Slot 3:
Serial 2T (12in1)
Hardware revision 1.0 Board revision D0
Serial number 35817651 Part number 800-03181-01
FRU Part Number WIC-2T=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 12 01 00 02 22 88 B3 50 0C 6D 01 00 00 00 00
0x30: 68 00 00 00 00 09 26 00 FF FF FF FF FF FF FF FF
ajagadee Sat, 12/20/2008 - 20:47
  • Cisco Employee,
Couple of things:
1. The FRU in the show diag shows the HWIC 4FE as PA-A3-OC3SMI=. This is only a cosmetic issue documented in Bug ID CSCsb96090 and should not affect the operation of the HWIC. This bug is fixed in 12.4(5) and higher
2. Could not get Card instance pa_bay = 0 slot = 1 from show diag output. This output is leading me to believe that the issue is more likely a hardware failure.
So, I would upgrade the code first and see if the FRU is reflecting the right part and also if the FE ports get recognized by the router. If not, try putting the HWIC in a different slot.
If you still have issues, you may need to open a TAC Service Request and request a replacement. Ofcourse, TAC needs to their troubleshooting first and then decide the course of action.
Arul
*Pls rate all helpful posts*
