SNMP traps with WLC 4402
Dec 18th, 2008
Currently using WLC 4402 with about a dozen WAPs. I would like to start logging some messages to troubleshoot some association issues. The syslog does not seem adequate for this the issues I am having. I noticed the default SNMP traps but is only holds 255 traps. I have tried to setup an SNMP server to get the traps but I get no data, only OID values. I was successful in getting the MIBs for the OIDs but still not all the data that I see on the brief traps screen.
hadbou Wed, 12/24/2008 - 10:09
  • Bronze, 100 points or more
It seems like the Context in SNMPV2 table was not getting intialized properly.
dennischolmes Wed, 12/24/2008 - 16:35
  • Gold, 750 points or more
Run your LWAPP debugs. Everything you need to know about AP and client association is contained in those logs. SNMP really only helps with WLC to WCS communications.
Pravin Phadte Tue, 01/06/2009 - 23:26
  • Silver, 250 points or more
I have tried it with solarwinds and works fine for me. Talking about the traps. But they are too many.
The OID is : 1.3.6.1.4.1.14179.1.1.2.4.1.22
snmp info for polling:
MIB Value Type: Raw Value
Format: None
SNMP Get Type: Get Table
Polling Type: node
On WLC go to Managemnet (top TAB)
Right hand select > SNMP > Traps Control.
In this menu select what traps to need to be logged.
These traps will be shows on the oid polled.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
