IPSec Preferred Peer
Dec 18th, 2008
Hi everyone,
I am pretty new to vpn configs and am trying to get ipsec preferred peer to work but I am having some problems.
I've tried a failover with the provider. It worked fine but when all interface on the primary telco router were restored I couldn't establish the vpn. I manually removed the peers config, added again and then I was able to establish connection with the default peer 172.31.41.169
Has anyone tried this kind of config before? I am using a cisco 3845.
crypto map Telecom 160 ipsec-isakmp
set peer 172.31.41.169 default
set peer 172.31.41.170
set security-association idle-time 60
set transform-set Standard_transform
match address 160
muca Mon, 01/05/2009 - 14:53
Hi Iris,
I read that document before. In my case I think the problem is an IOS bug.
bug CSCsc98737
CSCsc98737 Bug Details
VPNSPA:IKE/IPSec default peer functionality with idle timer is not OK
None
Symptom:
When we configure the default route, every new connection should check for default peer before it starts a new connection. Here that check is not happening.
