IP address summarization
Dec 18th, 2008
Hello all,
just need an explanation why C & D are the correct answer for the following 2 questions please:
10. Given the addresses 10.1.8.0/24 and 10.1.9.0/24, which of the following is the best summary?
a. 10.0.0.0/8
b. 10.1.0.0/16
c. 10.1.8.0/23-correct answer
d. 10.1.10.0/24
11. Given the addresses 10.1.138.0/27, 10.1.138.64/26, and 10.1.138.32/27, which of the
a. 10.0.0.0/8
b. 10.1.0.0/16
c. 10.1.138.0/24
d. 10.1.138.0/25-correct answer
Jon Marshall Fri, 12/19/2008 - 03:11
Mohammed
No 10
/23 = 255.255.254.0
256 - 254 = 2
So with a /23 you have 2 x /24 networks.
10.1.8.0/24
10.1.9.0/24
No 11
/27 = 255.255.255.224
/26 = 255.255.255.192
256 - 224 = 32
256 - 192 = 64
So
10.1.138.0/27 = 32
10.1.138.64/26 = 64
10.1.138.32/27 = 32
32 + 64 + 32 = 128
/25 = 255.255.255.128
256 - 128 = 128
If that is unclear then we can do it in binary if you want.
Jon
mhasabal Sat, 12/20/2008 - 13:54
John,
thank you so much for the reply.
i am trying to avoid doing it binary cause it takes a long time.
i do understand #11
but #10 i don't understand the part "So with a /23 you have 2 x /24 networks."
thanks again for your help
Jon Marshall Sun, 12/21/2008 - 05:16
Mohammed
10.1.8.0 255.255.255.0
10.1.9.0 255.255.255.0
Now you need to summarise these with just one entry. So a class C subnet mask of 255.255.255.0 will not work.
Which octet changes in the 2 subnets ie.
10 is the same for both so 10.
1 is the same for both so 10.1
the 3rd octet is the one that changes so we can derive a subnet mask so far of
255.255.
so at the moment we have
10.1 255.255
Now we know we cannot use 255 in the 3rd octet for the subnet mask because this would only allow 1 of the above subnets ie.
either 10.1.8 OR 10.1.9 but not both
If you wrote this out in binary it would become obvious but we need a value in the 3rd octet of the subnet mask that covers 2 class C networks
256 - 254 = 2
so we know that we can get 2 networks by making the 3rd octet 254. Again if we did this in binary it would be obvious but we are trying to give you an easier/quicker way to do it.
So the subnet mask now is 255.255.254. and this subnet mask covers 10.1.8 AND 10.1.9
Add a 0 at the end of the subnet mask and we end up with
10.1.8.0 255.255.254.0
A very quick bit of binary - you don't need to remember this it's just so you can understand how we get /23
128 64 32 16 8 4 2 1
if each of the 8 values had the binary bit on then they would all add up to 255. To get 254 we simply turn the last bit off ie. the value of 1 in the above is turned off. So the first 7 values above are on the last value is off.
Finally :-), using the subnet mask 255.255.254
255 = 8 bits on
255 = 8 bits on
254 = 7 bits on (last bit off)
8 + 8 + 7 = 23
Hope this makes sense.
Jon
subnetip1 Thu, 12/25/2008 - 14:31
Let's say that for Example 11, /27 and /26 are 32 IPs and 64 IPs, and when you look at their network address, these 3 blocks belong to the same first 128 IPs, which means a /25. C is too big and others are much too big. Same story for Example 10.
You can test yourself at subnetip.com; it's free and there is no registration.
Good luck!
