Is there a CatOS command equivalant to "terminal length 0" for IOS
loytakmem
Is there a CatOS command equivalant to "terminal length 0" for IOS ?
I writing a Expect script and I have CatOS with don't accept this command.
Hope there is something that allow it no stop at [more] prompt.
At the same note, from "show version" what is the keyword that allow us to know its a CatOS or IOS.
Jon Marshall
Loy
set length 0
Jon
you need to use:
"set length 512" for example, like I know you can use 512 charakters... but try it with more.
For the System Software i found a solution: show flash, here you can see the file name cat4000-k8.....
Best regards
Sebastian
