information about asa 5505
Dec 19th, 2008
Hi to all, i need to buy an asa 5505 but i have a doubt about the number of user, if i buy a license for 10 user i can connect behind the asa an unlimited number of pc or as the checkpoint i have a limit of 10 pc? Or the license is about the vpn supported?
Thanks and best regards,
Carlo S.
robbhanMid Fri, 12/19/2008 - 06:03
The license restriction is about the number of concurrent ssl and / or vpn connection.
You can have as many LAN clients as you like
ajagadee Fri, 12/19/2008 - 07:50
  • Cisco Employee,
If you have a 10 user license, that basically means you can have only 10 pc or users.
For example, show version output:
Inside Hosts : 10
The VPN Licensing can be found in the below outputs.
VPN Peers : 25
WebVPN Peers : 2
Arul
*Pls rate all helpful posts*
