PA-4E1G not supporting Multilink
I have cisco 7609-S router(12.2(33)SRA6), where i have WS-X6582-2PA enhanced flexwan module. There are two no. of PA-4E1G cards installed in enhanced flexwan.
There are two problems"
1. It is in unknown state but traffic is flowing through card.
2. When i am trying to configure multilink , i am not able to add the interface of PA-4E1G in the bundle.
pls suggest whether it is h/w problem or s/w issue? and how it can be corrected?
rgds
Giuseppe Larosa Fri, 12/19/2008 - 05:40
Hello Punit,
I would first verify with sh module the state of the linecard WS-X6582-2PA
A state of unknown doesn't allow to add the ports on the multilink bundle it means the supervisor has no control over it so point 2) comes from the unknown state.
12.2(33)SRA6 7609-S
do you see it in the diag
I have a CISCO7609 with c7600s72033-advipservicesk9_wan-mz.122-18.SXF14.bin and a 4E1 PA working over it
c7609#sh diag
Slot 2: Logical_index 4
2 port adapter FlexWAN controller
Board is analyzed ipc ready
HW rev 1.6, board revision B0
Serial Number: SAD074804X9 Part number: 73-3869-08
Slot database information:
Flags: 0x2004 Insertion time: 0xA5B895B8 (25w3d ago)
Controller Memory Size:
112 MBytes CPU Memory
16 MBytes Packet Memory
128 MBytes Total on Board SDRAM
IOS (tm) cwlc Software (cwpa-DW-M), Version 12.2(18)SXF14, RELEASE SOFTWARE (fc1)
PA Bay 0 Information:
T3+ Serial PA, 2 ports
EEPROM format version 1
HW rev 3.00, Board revision A0
Serial number: 32833119 Part number: 73-3761-03
Slot 2: Logical_index 5
Flags: 0x2004 Insertion time: 0xA5B88950 (25w3d ago)
PA Bay 1 Information:
>>> G703 Serial PA, 4 ports
HW rev 1.01, Board revision C0
Serial number: 16404629 Part number: 73-2231-04
c7609#
Hope to help
Giuseppe
