IP Phone 7906
Answered Question
Dec 19th, 2008
How to put a static IP address on my IP Phone 7906 and how to change the dhcp address?
Correct Answer by david-lima about 8 years 7 months ago
Hi, this option by default is locked, press **# to unlock this option and you will be able to set the appropiate value.
Hope this help
David
Overall Rating: 5 (1 ratings)
david-lima Fri, 12/19/2008 - 05:18
  • Bronze, 100 points or more
Hi, to put a static IP Address: Settings->Network Configuration->DHCP enabled=NO and you can configure a static IP, SubnetMask, TFTP IP Address....
Choose Yes if you want to use DHCP to automatically configure the network settings on your server.
Hope this help
David
p.maillot Fri, 12/19/2008 - 05:32
DHCP enabled = Yes there are no possibility to modify, I can choose only "exit" function, there are no option to choose "select"
Correct Answer
david-lima Fri, 12/19/2008 - 05:56
Hope this help
David
