replace 4503 Supervisor error
Dec 19th, 2008
hi everyone
Our Catalyst 4503-E switch's Supervisor module failed. We replace it other 4503-E switch's supervisor with same model. Two supervisor and switch model are same. But when ı power on failed 4503 it has show error on console like that "unkown backplane" and it restart always.what do you think this problem and how can ı solve it.
neteksadmin Fri, 12/19/2008 - 05:34
thanks for message
But this supervisor has been already operate in 4503-E(operate normal).We rip this from 4503-E chassis and took it our failed 4503-E chassis. I think, if it has older IOS it didn't operate other 4503-E chassis.
Mark Yeates Fri, 12/19/2008 - 06:11
You are probably right and are running right version. I would suggest putting in a TAC case on the chassis. Sounds like something might have gone wrong with the backplane on the chassis.
neteksadmin Fri, 12/19/2008 - 06:29
hmm oke. ı found what is TAC. but ı think it couldn't solve my problem.
Mark Yeates Fri, 12/19/2008 - 06:37
TAC will assist you in troubleshooting or RMA a faulty product. You must have a smartnet contract to be able to do this. If you are able to open a TAC case they will be able to solve your problem.
