On-net site codes
jheckart
Level 3
Level 3
I am currently bringing multiple sites into CUCM 7, all connected via IP. These sites have overlapping dial-plan's, and changing from 4 to 5 digit dialing is not an option.
I would like to utilize site codes. I found documentation that utilizes route patterns, but I do not see how a route pattern would work as I am not using a route list to reach the other sites. The other sites would essentially be seperated by partitions.
Thanks.
Brandon Buffin
One option is to use a translation pattern to strip the site code and send the call to the DN in the proper partition.
Hope this helps.
Brandon
6 Replies 6
Brandon Buffin
Hope this helps.
Brandon
Brandon,
Thanks for the response. This is helpful.
Would this be a typical solution:
Site A
A-DN-Part
A-SiteCode-Part -> Containing TP's
A-Unres-CSS -> Containing only local route partitions, VM etc.
Site B
B-DN-Part
B-SiteCode-Part -> Containing TP's
B-Unres-CSS -> Containting only local route partitions, VM etc.
A-TP
81.XXXX
Partition -> A-SiteCode-Part
CSS -> B-Unres-CSS
B-TP
82.XXXX
Partition -> B-SiteCode-Part
CSS -> A-Unres-CSS
Thanks for the help!
Yes, that is correct. You would configure the translation pattern with a digit discard instruction of PreDot which would strip the 81 or 82 and then ring the proper extension.
Hope this helps.
Brandon
Thanks so much.
How do you typically handle a centralized Unity implementation in this environment?
I guess that I could have a pilot per site that would have access to the voicemail ports, and all users mailboxes would be site-code + 4digit.
