Warning message
LAN BASED FAILOVER - problem pinging interfaces
Dec 19th, 2008
hi there
im trying to configure lan based failover on ASA 5510 (which ive sucessfully created in test lab using asa5510) but there is this strange issue where i cant ping the e0/3 interface prior to confiuring the failover.
So far, ive created a vlan 41 on a cisco 2960switch and placed inter g0/12 (which is conencted to primary ASA e0/3 which i will used as the failover interface into that vlan. the ip add of e0/3 is 192.168.254.1/24
Then, ive placed inter g0/11 (which is connect to secondary asa inter e0/3) into vlan 41 with interface ip of 192.168.254.2/24.
Now prior to entrering the relevant failover commands, i should be able to ping at least the e0/3 interfaces on both ASA's? well i cant.
Ive checked the speed and duplex settings on asa's and switch and all set to 100MB full.
any ideas?
sh vlan brief output:
41 VOICE_FAILOVER active Gi0/11,Gi0/12
sh interface status
Gi0/11 connected to SupAS connected 41 full 100 10/100/1000BaseTX
Gi0/12 connected to SuppA connected 41 full 100 10/100/1000BaseTX
sh interface e0/3 (ASA 1)
Interface Ethernet0/3 "", is up, line protocol is up
Hardware is i82546GB rev03, BW 100 Mbps
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Available but not configured via nameif
MAC address 001e.f762.c8b3, MTU not set
IP address 192.168.254.1, subnet mask 255.255.255.0
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (4/0) software (0/0)
output queue (curr/max blocks): hardware (0/0) software (0/0)
sh interface e0/3 (ASA sec)
MAC address 001e.f762.9c8b, MTU not set
0 L2 decode drops
0 input reset drops, 0 output reset drops
input queue (curr/max packets): hardware (0/16)
output queue (curr/max packets): hardware (0/0)
Also, ive noticed that although the interfaces are up and up, the 192.168.254.0/24 network is not showing as connected under the sh route command.
what other info would be needed? As i said the failover conmmands havent been entered yet, i want to undastand why i cant ping the interfaces e0/3.
thanks
solpandor Fri, 12/19/2008 - 08:19
hi all
got it. It was to do with the fact that I didnt enter the nameif command on the e0/3 interfaces. i thought that was optional (apparantly not )
so looks like you need the nameif command as well for the network to show as connected under sh route
