ACS Java Error "Invalid RSA Modulus Size"
I just added a new certificate to an ACS server with 4.2 installed. The certificate took fine, but after I enabled https the login page will not load the Java applet. I cannot go into the application locally to disable it, because the automatically login locally check box is unchecked. I am looking for a way to disable ssl for CSAdmin via CLI on windows. After this I will request a new certificate and install it.
The Java console shows the following error in it's log:
javax.net.ssl.SSLProtocolException: java.io.IOException: subject key, Unknown key spec: Invalid RSA modulus size.
This is referenced by multiple classes not just javax.net.ssl.
bstremp Sun, 12/28/2008 - 18:22
You may try uninstalling and reinstalling the certificate on ACS
