12-19-2008 08:23 AM - edited 03-06-2019 03:03 AM
Hi All,
Is turbo ACL feature is supported on Cisco 3845 router ?
Anantha Subramanian Natarajan
Solved! Go to Solution.
12-19-2008 08:32 AM
Anantha :-),
TurboACLs were deprecated on the ISR platforms starting with 12.4(15)T and this is
documented in the following DDTS.
CSCsg49131 - TACL code should not be there on the ISR platform
This is only specific to the ISR's (28xx and 38xx).
Arul
*Pls rate all helpful posts*
12-19-2008 08:32 AM
Anantha :-),
Arul
12-19-2008 08:50 AM
Hi Arul,
Thank you very much
