upgrade 3550 smi to emi?
Answered Question
Dec 19th, 2008
What does it take to upgrade a 3550 from SMI to EMI and is it possible?
Correct Answer by Edison Ortiz about 8 years 1 month ago
I don't think so - why would you need a bigger flash? The EMI image will fit in your current flash space. The SMI image will be removed during the upgrade.
___
Edison.
Technically, it's just a software update. Legally, you must purchase the upgrade via a Cisco Reseller.
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Correct Answer
Edison Ortiz Fri, 12/19/2008 - 09:10
HTH,
__
Edison.
Correct Answer
Edison Ortiz Fri, 12/19/2008 - 09:27
___
Edison.
glen.grant Fri, 12/19/2008 - 09:41
Can you even get this ? The 3550 is eol and the end of software releases ended in May 2007.
Edison Ortiz Fri, 12/19/2008 - 09:59
Glen,
You are absolutely right, the following link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps646/prod_end-of-life_notice0900aecd8029f777.html
states May 2007 is the cut-off date for Software Release.
With that said, 12.2(46)SE was released not to long ago:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.2_46_se/release/notes/OL16493.html
Thus, I'm not sure what that business unit's plan really is..
__
Edison.
