terminal server/reverse telnet server disconnect
Dec 19th, 2008
I have a reverse telnet server (2620 with a async card and the octal cable)
I can terminal in fine but I can't get it to "kill" my session when I exit. I then have to go out and do a show line and <clear line tty 2033> This is irratiting me!!I seem to recall using a terminal server that would automatically log you out, return you to the terminal server. Any suggestions?
Overall Rating: 4 (1 ratings)
Edison Ortiz Fri, 12/19/2008 - 09:07
  • Hall of Fame,
    Founding Member
It should log out all active sessions "if" you type exit on the terminal server session.
User Access Verification
Password:
Rack9Pod1>r1
Trying R1 (10.1.1.1, 2001)... Open
Rack1R1#
Rack9Pod1>exit
(You have open connections) [confirm]
Closing: r1 !
___
Are you returning to the terminal server with CTRL+SHIFT+6?
___
Edison.
Richard Burts Fri, 12/19/2008 - 09:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jason
In addition to the suggestion from Edison to use exit, I typically use shift/CTRL/6 x to get back to the term server and then type disconnect to terminate the session to the remote.
Rick
