3 Sites using 3 UC500
Dec 19th, 2008
Hi guys I was wondering if there's a way or it's possible to install 3 different sites on different locations each one with a UC500 16 Users, and share extensions and be able to communicate with other sites, if it is, can you help me with some guidelines and best practices?
Nicholas Matthews Fri, 12/19/2008 - 09:22
  • Red, 2250 points or more
Yes, you can do this.
What you will end up with is dial peers pointing towards the other sites.
If you have 3 sites, say A has extensions 1.., B has 2.., and C has 3..
You would have dial peers on each site that point those extensions to the other ones via SIP or H323.
Site A:
dial-peer voice X voip
destination-pattern 2..
session target ipv4:
destination-pattern 3..
Site B:
destination-pattern 1..
...etc
You would in essence, create a fully meshed H323 or SIP trunk between each site.
