ASIC on 3560/3750
Endorsed Question
Does anyone have a document that shows the ASIC mappings on these two switches. I am looking for something that will show port 1-5 in on the first asic and 6-10 and the second etc. Ideas?
Cisco Endorsed by operezsa
Edison Ortiz about 8 years 4 months ago
ASIC stands for Application-Specific Integrated Circuit. On a switch, there are many ASICs - you can have an ASIC dedicated for NetFlow, ACLs, among other services.
The more ASICs you have in a switch, the less you use the CPU for those services hence making the switch a lot faster.
In the 6500/4500, the ports are group due to the oversubscription nature and they are physically connected to an ASIC. This hardware controls traffic to/from the port or group of ports.
HTH,
__
Edison.
Overall Rating: 5 (2 ratings)
Edison Ortiz Fri, 12/19/2008 - 13:30
  • Hall of Fame,
    Founding Member
The port-grouping is done in modular switches such as 4500 and 6500 due to the limited backplane capability.
3560/3750 perform wire rate switching and do not implement any kind of port-grouping.
HTH,
__
Edison.
Edison Ortiz Fri, 12/19/2008 - 14:06
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
Edison Ortiz Fri, 12/19/2008 - 14:03
  • Hall of Fame,
    Founding Member
Yes, all that information is contained in the data sheet provided in the post above mine.
Wire rate means speed that equals to the speed of the port, there isn't any oversubscription like in the 6500 and 4500 switches.
Joseph W. Doherty Fri, 12/19/2008 - 19:25
I haven't seen that documented.
For the later 3750-E, there's: http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_presentation09186a0080161372.pdf. I would think the non-E architecture might be somewhat similar.
Since original StackWise ports are 8 Gbps and the 10 gig port on the 3750G-16TD only could sustain 8 Gbps, and the fabric is noted as 32 Gbps, I think there's a chance port ASICs in the 3560/3750 support 8 Gbps.
Joseph W. Doherty Tue, 12/23/2008 - 11:38
Addendum:
Just came across the "sh platform pm if-numbers", which in column "port" might note the ASIC port as the first value.
nelcnetworks Thu, 02/07/2013 - 05:08
Guys,
Dont know if this is of any use but the commend on a 3560 - sh platform pm platform-block gives the following
A04S05-3560-20#sh platform pm platform-block
interface gid gpn lpn asic hw-i flags sp dp bundle vlan mvid mac so_di i_vlan
Fa0/1     3   3   1   1    2       U  2  2  no     0    0    0   61443  0
Fa0/2     4   4   2   1    3       U  1  2  no     0    0    0   61444  0
Fa0/3     5   5   3   1    4       U  2  2  no     0    0    0   61445  0
Fa0/4     6   6   4   1    5       D  2  2  no     0    0    0   61446  0
Fa0/5     7   7   5   1    6       D  2  2  no     0    0    0   61447  0
Fa0/6     8   8   6   1    7       U  1  1  no     0    0    0   61448  0
Fa0/7     9   9   7   1    8       U  2  2  no     0    0    0   61449  0
Fa0/8     10  10  8   1    9       U  2  2  no     0    0    0   61450  0
Fa0/9     11  11  9   1    10      U  2  2  no     0    0    0   61451  0
Fa0/10    12  12  10  1    11      U  2  2  no     0    0    0   61452  0
Fa0/11    13  13  11  1    12      U  2  2  no     0    0    0   61453  0
Fa0/12    14  14  12  1    13      U  2  2  no     0    0    0   61454  0
Fa0/13    15  15  13  1    14      U  2  2  no     0    0    0   61455  0
Fa0/14    16  16  14  1    15      U  2  2  no     0    0    0   61456  0
Fa0/15    17  17  15  1    16      U  2  2  no     0    0    0   61457  0
Fa0/16    18  18  16  1    17      U  2  2  no     0    0    0   61458  0
Fa0/17    19  19  17  1    18      U  2  2  no     0    0    0   61459  0
Fa0/18    20  20  18  1    19      U  2  2  no     0    0    0   61460  0
Fa0/19    21  21  19  1    20      U  2  2  no     0    0    0   61461  0
Fa0/20    22  22  20  1    21      U  2  2  no     0    0    0   61462  0
Fa0/21    23  23  21  1    22      D  1  2  no     0    0    0   61463  0
Fa0/22    24  24  22  1    23      U  1  1  no     0    0    0   61464  0
Fa0/23    25  25  23  1    24      U  2  2  no     0    0    0   61465  0
Fa0/24    26  26  24  1    25      U  2  2  no     0    0    0   61466  0
Fa0/25    29  29  25  0    2       U  2  2  no     0    0    0   61469  0
Fa0/26    30  30  26  0    3       U  2  2  no     0    0    0   61470  0
Fa0/27    31  31  27  0    4       U  2  2  no     0    0    0   61471  0
Fa0/28    32  32  28  0    5       U  1  2  no     0    0    0   61472  0
Fa0/29    33  33  29  0    6       U  2  2  no     0    0    0   61473  0
Fa0/30    34  34  30  0    7       U  2  2  no     0    0    0   61474  0
Fa0/31    35  35  31  0    8       U  2  2  no     0    0    0   61475  0
Fa0/32    36  36  32  0    9       U  2  2  no     0    0    0   61476  0
Fa0/33    37  37  33  0    10      D  0  0  no     0    0    0   61477  0
Fa0/34    38  38  34  0    11      U  2  2  no     0    0    0   61478  0
Fa0/35    39  39  35  0    12      D  0  0  no     0    0    0   61479  0
Fa0/36    40  40  36  0    13      U  2  2  no     0    0    0   61480  0
Fa0/37    41  41  37  0    14      D  1  2  no     0    0    0   61481  0
Fa0/38    42  42  38  0    15      U  2  2  no     0    0    0   61482  0
Fa0/39    43  43  39  0    16      D  1  2  no     0    0    0   61483  0
Fa0/40    44  44  40  0    17      U  2  2  no     0    0    0   61484  0
Fa0/41    45  45  41  0    18      U  2  2  no     0    0    0   61485  0
Fa0/42    46  46  42  0    19      U  2  2  no     0    0    0   61486  0
Fa0/43    47  47  43  0    20      U  2  2  no     0    0    0   61487  0
Fa0/44    48  48  44  0    21      D  0  0  no     0    0    0   61488  0
Fa0/45    49  49  45  0    22      U  2  2  no     0    0    0   61489  0
Fa0/46    50  50  46  0    23      D  0  0  no     0    0    0   61490  0
Fa0/47    51  51  47  0    24      U  2  2  no     0    0    0   61491  0
Fa0/48    52  52  48  0    25      U  2  2  no     0    0    0   61492  0
Gi0/1     1   56  49  1    0       U  3  2  no     0    0    0   61496  0
Gi0/2     2   57  50  1    1       U  3  2  no     0    0    0   61497  0
Gi0/3     27  27  51  0    1       D  0  0  no     0    0    0   61467  0
Gi0/4     28  28  52  0    0       D  0  0  no     0    0    0   61468  0
Po1       56  56  0   0    0       U  0  0  no     0    0    0   61496  0
A04S05-3560-20#
which appears to show two asics, each controlling 26 ports (24 Fa and 2 Gi) (Po may be even distributed between asics)
hope it helps.
