Warning message
Question CUCM Upgrade Check List
Hi Guys:
Does anyone have a (new install check list) that I can use?
We are migrating from CM 4.1x to CUCM 6.1 with 2 Unity 5x Servers.
I need the list from a technical stand point. What are some of the items I can look for right off the batt?
For example, Ping, Trace Route, Trace files, PRI's, Codec's, Signaling, where phones are registered, Call handlers and Subscribers, Attendant Console, Services, are the DB's running.
Are there any favorite items the experienced guys look for immediately after the Server is on line in a live environment?
My testing will be done in a lab environment 2 days before… and immediately after the new CUCM 6.1 goes live in the real environment.
Finally, we are changing out 4 gateways 3 days before the upgrade. 6608's CAT OS to 2851 IOS.
Any big items to look for on the gateway swap out.
Thanks, Tom
