CCIE TRACK OR CCNP
Dec 19th, 2008
I already have a ccna and i have little production experience.
My aim is to do CCIE but i am a confused.
Should i go ahead with CCNP first and then do CCIE R&S
OR
I should directly go for CCIE R&S??
Please advice so ican sart working on it as soon as possible.
Overall Rating: 3.5 (2 ratings)
seagordo Fri, 12/19/2008 - 10:26
First, figure out how to get experience. Then take your learning from there...
jim_berlow Fri, 12/19/2008 - 11:22
I highly recommend that you do the CCNP considering that you have little experience. This is a great stepping stone to the CCIE and the way that most people do it. I can assure you that you will not be wasting your time and that the CCNP will actually help you to complete the CCIE later.
Good Luck,
Jim
