Redundancy with Sup720
Dec 19th, 2008
I am having with 2 Sug720 -10G modules for a 6509 chassis. The standby supervisor is coming up as unknown status and the reduancy is showing as down when i do a show redundancy state.. The config I have applied is below
mode sso
auto-sync running-config
Am I missing a command? Is anybody having similar issues with these supervisor modules?
Mark Yeates Fri, 12/19/2008 - 11:38
Are you able to console into the standby supervisor and make sure it not stuck in rommon.
Mark Yeates Fri, 12/19/2008 - 12:08
You can type the command "boot". I would also make sure the config-register is correct on your standby supervisor to make sure it doesn't sit in rommon upon reboot. type "confreg 0x2102" in rommon, then type "reset".
Derek McCormick Fri, 12/19/2008 - 12:11
i have tried this and this does not boot the switch. I presume the image is corrupt. Is there a way around this? can i not copy the image from the primary sup to the backup sup
Is there a command to do this?
Mark Yeates Fri, 12/19/2008 - 12:13
Not from rommon. what is the output of "dir bootflash:"? Also if you have a compact flash card you can copy the IOS from the primary and boot the standby from the CF card. If not you may need to use xmodem to load a bootable image from rommon.
