CCIP Question.
Dec 19th, 2008
I passed my BSCI and am working on QOS. I noticed mentioned that doing BGP is helpful first. Does the list that presents, BSCI, QOS, then BGP+MPLS is that the most logical flow or should I be doing the BGP+MPLS prior to QOS?
Also, to anyone who has wrote and passed QOS, how did it compare to BSCI and did since CCIP doesn't have the resources online that CCNP does, do you have any recommendations.
tperrier Mon, 12/22/2008 - 01:03
The QOS exam is pretty much independant, you can take it anytime you'd like.
I found the QOS exam easier than the BSCI, but I was a bit weak in routing at the time, so YMMV! The Cisco Press QoS book is excellent preparation, even though not online content (unlike you use Safari, of course!).
leopastor Mon, 01/05/2009 - 06:53
The consideration on QoS is correct, but I would follow Cisco recommendation!
