Cisco ACE Sticky?
What would be a resonable initial sticky percentage? I started with 5% on the following command syntax:
resource-class prod
limit-resource sticky minimum 5.00 maximum unlimited
I haven't had the opporunity to allocate my resources as needed because I do not have enough servers on the ACE environment yet. I currently have a total on three virtual context including the Admin context.
Thanks in advance,
John...
Overall Rating: 5 (1 ratings)
Gilles Dufour Tue, 12/23/2008 - 14:31
John,
there is no magic number.
Be aware that sticky resources can't grow.
So 5% is all you get even if you configure maximum unlimited.
I would suggest to do a 'show resource usage' to see how much you are already using.
If necessary, increase the resource.
Do you expect to grow by 20 times in the future ? 5% is only 1/20 of the resource and if you do not expect to grow, why save the resource ?
G.
