ASA 5505 Help
Dec 19th, 2008
I am configuring an ASA 5505 for a small business client to replace Linksys router, and I am having some trouble with it. Any help would be greatly appreciated. Here is my config:
sh run
: Saved
ASA Version 7.2(4)
hostname ciscoasa
names
name 192.168.32.5 mailserver
interface Vlan1
nameif inside
security-level 100
ip address 192.168.32.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xx.xx.215.35 255.255.255.224
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
port-object eq smtp
port-object eq 444
port-object eq imap4
port-object eq 4125
port-object eq pptp
port-object eq ftp
port-object eq 3389
port-object eq pop3
port-object eq 995
access-list inside_access_in extended permit tcp any host mailserver object-group DM_INLINE_TCP_1
pager lines 24
logging enable
logging buffered informational
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface ftp mailserver ftp netmask 255.255.255.255
static (inside,outside) tcp interface https mailserver https netmask 255.255.255.255
static (inside,outside) tcp interface smtp mailserver smtp netmask 255.255.255.255
static (inside,outside) tcp interface 444 mailserver 444 netmask 255.255.255.255
static (inside,outside) tcp interface imap4 mailserver imap4 netmask 255.255.255.255
static (inside,outside) tcp interface 4125 mailserver 4125 netmask 255.255.255.255
static (inside,outside) tcp interface pptp mailserver pptp netmask 255.255.255.255
static (inside,outside) tcp interface 3389 mailserver 3389 netmask 255.255.255.255
static (inside,outside) tcp interface 995 mailserver 995 netmask 255.255.255.255
static (inside,outside) tcp interface www mailserver www netmask 255.255.255.255
static (inside,outside) interface mailserver netmask 255.255.255.255
access-group inside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 xx.xx.215.33 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 192.168.32.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:916a58426e2cb7b4d44cdbc0446fcfad
: end
ciscoasa#
Here is the routing table (nothing plugged in right now other than console):
Gateway of last resort is not set
C 127.0.0.0 255.255.255.0 is directly connected, _internal_loopback
When I have the client connect the asa, no connectivity in or out works. They have two layer 2 switches, no routers.
JORGE RODRIGUEZ Fri, 12/19/2008 - 20:43
C 127.0.0.0 255.255.255.0 is directly connected, _internal_loopback<
Hi Wendi,
You need to start making the physical connection in your inside switch and outside interfaces first before atempting to connect to internet or from outside internet to inside.
show route does not indicate any physical connectivity to anything .
wendigoulette Sat, 12/20/2008 - 06:42
Hi, thank you for your reply. I noted in my post that when it IS plugged in, nothing works. I am very aware that connectivity to anywhere will not work without a physical connection. :o)
My concern is mostly my config - I'm looking for any suggestions on what I may have configured incorrectly.
Oh, one other note - shouldn't my static default route be displayed in the routing table whether it is connected or not?
JORGE RODRIGUEZ Sat, 12/20/2008 - 08:11
Hi Wendy, the default route will show up in routing table once the upstream router is reachable.
I meant also to repost my answer few minutes later thinking that you must have placed back the linksys router becuase connectivity to internet was not happening, my apologies for that, I would have done exactly the same.
When you connect back the firewall connections to inside and outside from firewall itself try pinging your defalt route to confirm you can reach that upstream router. The access from inside to outside by default is permited but you will need some dns configuration for the PC inside to DNS query weblinks.
you could try dhcp address for inside interfaces if you don't have dhcp server and use a public opened DNS servers 208.67.222.222,208.67.220.220
and have this be automatically given to inside hosts dynamically
Example :
dhcpd dns 208.67.222.222 208.67.220.220
dhcpd address 192.168.32.10-192.168.32.100 inside
dhcpd enable inside
for the acl to get access to inside mailserver I would try :
access-list inside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_1
but...I would recommend to change the acl name instead of the " inside_access_in " to sort of distinguish what comes from outside to inside within acl names, like outside_access_in gives clear picture for your outside interface acls.
access-list outside_access_in extended permit tcp any interface outside object-group DM_INLINE_TCP_1
access-group outside_access_in in interface outside
remove old one
no access-list inside_access_in extended permit tcp any host mailserver object-group DM_INLINE_TCP_1
wendigoulette Sat, 12/20/2008 - 08:32
so the mailserver is also serving as dhcp server for the inside clients, which is why i turned off DHCP on the router. i have decided that i need to work on this in person - it's difficult to truobleshoot something that isn't plugged in. :) so i'm trying to arrange to make the trek to my client's sit on monday. once I figure out what's wrong I will post it here for future reference. :)
wendigoulette Mon, 12/29/2008 - 08:30
I haven't been able to coordinate a time to visit the customer until now - I will be going over there tomorrow evening. Will post the results here. :)
