anyone can help me?
Dec 19th, 2008
I have a old Ms-word copy of Running configuration of router 3600. I want configure this copy of running configuration into new 3600 router. I m new this one . can any one tell me step by step how to configure this.
ilnaiduccna Fri, 12/19/2008 - 21:02
Vinoth,
<>login into router 3600
<>go to config mode
<>do copy whatever configuration you want like if you want configure interface S0/0/0 then copy particular interface configuration then come to 3600-router go to interface S0/0/0 and do past here.
<>Like that you can copy required configuration from Ms-word then go to 3600-router Past in the required place.
Naidu.
vinothlb1 Fri, 12/19/2008 - 21:29
i want to copy all the running configuration.. what is to be done..
ilnaiduccna Fri, 12/19/2008 - 21:34
however you can copy all the running configuration and can just past into from config mode itself.
Naidu.
