Card VIC 4FXS/DID and 8FXS/DID
Answered Question
Dec 20th, 2008
I have installed one card VIC 4FXS/DID and one card 8FXS/DID on my Call Manager Express.
Card 4FXS/DID on port HWIC 1 and card 8FXS/DID on slot 4, how put and extension number to port 0/1/0 for exemple?
I want to put extension "110" to the port 0/1/0
Correct Answer by Nicholas Matthews about 8 years 6 months ago
If you have this, your configuration is correct. You have something else going on, which is very hard to speculate what it could be.
Some things to check:
No corlists configured
'show dial-peer voice summary' - make sure there aren't duplicate DNs or somewhere else it's getting dialed to.
'debug voip dialpeer' see which dialpeer is getting hit when you dial 110.
'show voice port summ' - make sure the port is up/up/on-hook
Check for number expansion that may be changing the numbers
Check any time-based call blocking under telephony service
hth,
nick
Correct Answer by david-lima about 8 years 6 months ago
H, verify that you have these commans in your router:
router(config)#voice rtp send-recv
in your active fastethernet
router(config-if)#h323-gateway voip bind srcaddr "the IP of your active fastethernet"
Hope this help
David
Overall Rating: 5 (2 ratings)
Nicholas Matthews Sat, 12/20/2008 - 05:29
  • Red, 2250 points or more
These will be pots dial peers.
dial-peer voice 555
destination-pattern 110
port 0/1/0
hth,
nick
p.maillot Sat, 12/20/2008 - 07:31
I have already this
dial-peer voice 1 pots
port 0/1/0
Analog phone 110 can call ip phone 100 but the ip phone 100 cannot call the analog phone 110.
Correct Answer
david-lima Sun, 12/21/2008 - 06:48
  • Bronze, 100 points or more
Hope this help
David
Correct Answer
Nicholas Matthews Sun, 12/21/2008 - 12:55
hth,
nick
