Router backup problem.??
Dec 20th, 2008
without connecting the 1600 router in LAN . how to take back up of the router with connecting a single pc.
glen.grant Sat, 12/20/2008 - 03:24
Plug it into the console port turn on logging a terminal emulator and then just do a show run command.
vinothlb1 Sun, 12/21/2008 - 03:12
Is there any other method? If want take back of IOS how to do?
Joseph W. Doherty Sun, 12/21/2008 - 04:33
On most devices, you can usually load an IOS via the console cable; don't know if the converse is supported by it too.
Much faster to use a network connection. At the minimum, could could Ethernet to interconnect a single PC with the router. A command simmilar to "copy flash: ttcp: | ftp: | rcp:" should prompt you for IOS name and ttcp or ftp or rcp server address and then copy your IOS to it.
viyuan700 Sun, 12/21/2008 - 04:35
install TFTP server on ur PC and then you can backup IOS by copy flash TFTP
vinothlb1 Sun, 12/21/2008 - 04:51
I have installed tftp server.. Still it shows not able to open...
viyuan700 Sun, 12/21/2008 - 09:37
What are ur ip address in PC and & router. HOw r u connectingPCandrouter
