C1841 fa0/0 up when unplug LAN cable
Answered Question
Dec 20th, 2008
When I unplug LAN cable from interface fa0/0 why interface still up but protocol down ?
It is default ? or we can set ?
Thank you in advance.
Correct Answer by Richard Burts about 8 years 4 months ago
teerapon
It is the default behavior of IOS routers such as the 1841 that if the FastEthernet interface is not plugged into some device then the interface will show as interface up and line protocol is down.
Rick
Correct Answer by scottmac about 8 years 4 months ago
If you have keepalives disabled, then the link will stay up.
Check your config, under that interface, for a "no keepalive" statement
Also make sure you are looking at the right interface ....
Good Luck
Scott
Overall Rating: 5 (2 ratings)
Correct Answer
scottmac Sat, 12/20/2008 - 07:22
  • Green, 3000 points or more
Good Luck
Scott
t.sriwetchasin Sun, 12/21/2008 - 18:28
Thank you Scott.
So, If I used "no keepalive" command under int fa0/0, interface and protocol will up both but I did not plug LAN cable into that interface.
I also check with another new router C1841. After completed boot and no shutdown the fastEthernet interface. FastEthernet interface is up without LAN cable connected.
It may be default of router? and How to make it down when we did not plug the LAN cable into interface ?
Environment
C1841
IOS c1841-ipbasek9-mz.124-23.bin
Thank you.
Correct Answer
Richard Burts Mon, 12/22/2008 - 08:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
teerapon
Rick
