Charlie Mayes Sat, 12/20/2008 - 14:09
I have this one loaded but do not see a MPLS IP option anywhere. I have already enabled CEF with ip cef. Am I missing something?
c2600-advipservicesk9-mz.124-10.bin
viyuan700 Sat, 12/20/2008 - 14:21
  • Silver, 250 points or more
on an interface you dont have mpls ip command / mpls lable protocoltype
viyuan700 Sat, 12/20/2008 - 14:30
go to config mode
then enter to any interface
with command like
int f0/0 or f0/1 etc then
you will have mode like
Hostname(config-if)#?
on that interface type ? hit enter you will see for mpls ip if it is there u have that feature
Charlie Mayes Sat, 12/20/2008 - 14:33
I have done that and I don't have that option at all. I check it before and thought it was weird. What now?
viyuan700 Sat, 12/20/2008 - 14:38
do you have mpls ip in config mode
Hostname(config)#?
do you have mpls ip here
Charlie Mayes Sat, 12/20/2008 - 14:39
It is not there either. I surely thought this IOS would contain it.
viyuan700 Sat, 12/20/2008 - 14:52
can you post ur
sh running-config
sh version
Charlie Mayes Sat, 12/20/2008 - 15:11
hostname HQ2
boot-start-marker
boot-end-marker
enable password cisco
aaa new-model
aaa authentication login default local
aaa authentication login VPNAUTH local
aaa authorization network VPNAUTH local
aaa session-id common
clock timezone NewYork -5
clock summer-time NewYork date Apr 6 2003 2:00 Oct 26 2003 2:00
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip domain lookup
ip domain name ike
crypto pki trustpoint TP-self-signed-1594146880
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1594146880
revocation-check none
rsakeypair TP-self-signed-1594146880
crypto pki certificate chain TP-self-signed-1594146880
certificate self-signed 01
3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31353934 31343638 3830301E 170D3032 30333031 30343537
31365A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 35393431
34363838 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100CE63 AFC8504A 697DA5EF 4535DAAC C81B5528 FAE58751 992F9BA7 B9180F72
EC017F4D 7A0E1C1E 4883D078 EA471F98 F0AF26CE 7A05870D 6EEF4400 0CE7C4F5
F6667021 1212A7E9 D25B27E2 FADDD347 CFCB75F4 8F19DF1F CE4AB46D E337D740
5274998A 2111A4DA AD5E1432 04817AD7 F8B2438F 2C890429 ABD34ABA B1EE1DE6
F6EB0203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
551D1104 0B300982 07485132 2E696B65 301F0603 551D2304 18301680 14D927D5
1E2F2AA4 1D4C3034 76EADB03 3A1B63C4 29301D06 03551D0E 04160414 D927D51E
2F2AA41D 4C303476 EADB033A 1B63C429 300D0609 2A864886 F70D0101 04050003
81810070 07191AD0 5C074CD2 18211AFE DDA175C5 4DD831E6 6A1C60B2 1D14F06A
E79A07CD EABFD1C0 DC55A8FC E0DBC398 1F606933 D0CCE88F 698135FE 56914C15
F59EAE92 570DD79E EA57E640 877085B2 8B08387B 0358F382 A03B269B 04BE0578
4A493D1A 5E09BFBD 6B41BD5C 4CBBA35D EA527A8E 81C0F455 2F1BA836 B9345143 3C9565
quit
username
username
username
username
username
crypto isakmp policy 10
encr aes 256
authentication pre-share
group 2
crypto isakmp keepalive 30 5
crypto isakmp xauth timeout 60
crypto isakmp client configuration group ciscogroup
key ciscogroup
pool VPNCLIENTS
acl 100
netmask 255.255.255.0
crypto ipsec transform-set mytrans esp-3des esp-sha-hmac
crypto dynamic-map mymap 10
set transform-set mytrans
reverse-route
crypto map mymap client authentication list VPNAUTH
crypto map mymap isakmp authorization list VPNAUTH
crypto map mymap client configuration address respond
crypto map mymap 10 ipsec-isakmp dynamic mymap
interface Loopback0
ip address 172.16.3.1 255.255.255.0
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
no fair-queue
interface FastEthernet0/1
description Outside interface
ip address dhcp
duplex auto
speed auto
crypto map mymap
router eigrp 1
network 172.16.0.0
no auto-summary
router rip
version 2
network 192.168.0.0
no auto-summary
ip local pool VPNCLIENTS 192.168.0.50 192.168.0.75
ip route 192.168.0.0 255.255.255.0 FastEthernet0/1
ip http server
ip http secure-server
access-list 100 permit ip 172.16.0.0 0.0.255.255 any
access-list 100 permit ip 192.168.0.0 0.0.255.255 any
control-plane
line con 0
line aux 0
line vty 0 4
password cisco
transport input ssh
end
Charlie Mayes Sat, 12/20/2008 - 15:12
HQ2#sh version
Cisco IOS Software, C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.4(10),
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 16-Aug-06 01:42 by prod_rel_team
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
HQ2 uptime is 6 days, 8 hours, 10 minutes
System restarted at 09:59:53 NewYork Sun Dec 14 2008
System image file is "flash:c2600-advipservicesk9-mz.124-10.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2621XM (MPC860P) processor (revision 1.0) with 127308K/3764K bytes of memo
ry.
Processor board ID JAE073416L8
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 Serial interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
Charlie Mayes Sat, 12/20/2008 - 16:19
Yeah I can agree this is weird. If you think for anything else let me know.
Charlie Mayes Sat, 12/20/2008 - 20:06
Hey I found a IOS that works for the 2621 MPLS lab finally.
c2600-adventerprisek9-mz.123-26.bin
Thanks for all your help.
viyuan700 Sat, 12/20/2008 - 20:21
pls see the other thread looks like whatever edison has said is true.
As the link i sent you say 2621XM support but sometimes there are so many things behind those simple words which we cannot decipher.
