ASA same-security-traffic inter
Dec 20th, 2008
Has anyone had experience with this? Instead of net statics can I just use nonat access-lists in each direction to accomplish the same thing? thx
JORGE RODRIGUEZ Sat, 12/20/2008 - 21:35
  • Green, 3000 points or more
Short answer is yes, you can configure a nonat exempt acl in both directions , will have same effect as if you had configured bidirectional identity NAT for the two same sec level interfaces.
