dynamic NAT from outside to inside
Answered Question
Dec 21st, 2008
Hello
Could you please let me know if it is possible to run the dynamic PAT on the FWSM module or ASA from the ouside to the inside interface, something like that:
nat (outside) 1 10.1.1.1 netmask 255.255.255.255
global (inside) 1 192.168.1.1
I tried to do that on my FWSM module but it seems not to work.
Thanks in advance
Lukas
Correct Answer by Jon Marshall about 8 years 4 weeks ago
Lukas
I have used this on a pix and ASA before but not an FWSM but there is no reason why it should not work. One change to make in your config -
change
to
nat (outside) 1 10.1.1.1 netmask 255.255.255.255 outside
ie. you need the keyword "outside" at the end of your nat statement.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Sun, 12/21/2008 - 05:20
Lukas
change
to
Jon
lukaszkhalil Sun, 12/21/2008 - 07:58
Hello
Is it possible that this nat with outside keyword can break the existing static (inside,outside)?
When I configure it, the dynamic NAT works but the static stops working.
