create DN in Callmanager 4.1
Answered Question
Dec 21st, 2008
Hi All,
I have not worked a lot with callmanager 4.1. How can I create DN without to create phones? In CUCM, DN can be created without to assign to any phone. can we do the same thing in CM 4.1?
thanks
Alex
Correct Answer by Jaime Valencia about 8 years 7 months ago
the DN alone creation is not implemented in CCM, only in CUCM. you'll have to create the phones using another MAC address, then delete them and they will go to unassigned DNs. that is the only way
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
Marwan ALshawi Sun, 12/21/2008 - 12:51
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
ok the question is what the idea in doing this ?
alex goshtaei Sun, 12/21/2008 - 12:55
thanks for reply,
We have 100 DID range, I'd like to create all extensions corresponded to the DID before to assign to any phone then show admin assistant how to add those DN to the phones. like CUCM 6.1
thanks again
Alex
david-lima Sun, 12/21/2008 - 14:30
  • Bronze, 100 points or more
Hi, you can insert the lines/phones with BAT and create dummy Mac address, then you can choose the DN and change it with the correct MAC Address.
Hope this help.
David.
Correct Answer
Jaime Valencia Sun, 12/21/2008 - 16:25
  • Cisco Employee,
  • Hall of Fame,
    2011
java
