New problem
Dec 21st, 2008
hi all
I have a problem as following:
My office have 2 Internet line (line 1 and line 2)connect via a cisco router 2811 (IOS AdIPvervice), I use route-map to load sharing internet traffic. Route-map, Rouing is ok. But several websites are not accessed, I check as Ping to that website as domain name and ip address are ok.
when I replace cisco router as a modem, that websites are accessed normal.
I have not solved this problem, i think route-map is ok, routing is ok, but dns have problem when use cisco IOS
any one have the same it ?
Please sharing
thanks
ducnv
passioncas Sun, 12/21/2008 - 22:53
It can be a problem with the Route-map configuration.If possible please send us the Route-map configuration
ducnv_isphn Sun, 12/21/2008 - 23:01
My configuration file:
interface FastEthernet0/0
description **** PPPoE to FPT ****
no ip address
ip flow ingress
ip flow egress
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface FastEthernet0/1
description **** PPPoE ADSL 4 Mbps, Hosting Web, mail ***
no ip address
ip flow ingress
ip flow egress
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
pppoe-client dial-pool-number 2
interface FastEthernet0/0/0
description **** Connect to LAN via Firewall1 ****
switchport access vlan 2
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface Vlan1
no ip address
interface Vlan2
description **** FOR connect to LAN ****
ip address 192.168.1.5 255.255.255.0
ip nat inside
ip policy route-map FPTH
interface Dialer0
description **** PPPoE to FPTH ****
mtu 1492
bandwidth 4000
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username HNFdl-080930-049 password 7 045D0F565E711817
interface Dialer1
description **** PPPoE for ADSL 4M, HOSTING WEB & MAIL ****
mtu 1492
ip nat outside
encapsulation ppp
dialer pool 2
dialer-group 2
ppp pap sent-username bmscadsl password 7 055B0C59291F405E17
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source list FPT interface Dialer0 overload
ip access-list standard DMZ
remark FOR ROUTE-MAP DMZ_ZONE
permit 172.16.2.0 0.0.0.255
ip access-list standard FPTH
permit 172.16.3.0 0.0.0.255
permit 172.16.4.0 0.0.0.255
permit 10.0.0.0 0.0.0.255
ip access-list extended FPT
permit ip 172.16.3.0 0.0.0.255 any
permit ip 10.0.0.0 0.0.0.255 any
permit ip 192.168.1.0 0.0.0.255 any
access-list 1 permit 172.16.2.0 0.0.0.255
route-map FPTH permit 10
match ip address FPTH
set default interface Dialer0
route-map FPTH permit 20
match ip address DMZ
set default interface Dialer1
