Transfer analog phone to IP Phone
Dec 22nd, 2008
I have a problem to transfer a call to analog phone from an IP Phone. On IP Phone, I can dial only two digit and after hook.
On analog phone, how to enable the transfer key? It's possible to use the "R" key on the phone keyboard?
There no problem of transfer ip phone to ip phone.
p.maillot Mon, 12/22/2008 - 02:06
I have add this command, but now the transfer is permit between anlog phone and IP Phone but transfer is not immediate, I must wait 5seconds or more. There are a solution for transfer immediate without time?
How to enable the transfer on analog phone?
CallManager(config-telephony)#transfer-pattern .T
CallManager(config-telephony)#call-forward pattern .T
david-lima Mon, 12/22/2008 - 05:08
  • Bronze, 100 points or more
Hi, maybe you could try a specific transfer pattern according to your dial-plan.
CallManager(config-telephony)#transfer-pattern ....
CallManager(config-telephony)#call-forward pattern ....
Or decrease the interdigit timeout (default is 15 sec).
CallManager(config-telephony)#timeout interdigit "value 2 to 120 sec"
Hope this help
David
p.maillot Mon, 12/22/2008 - 05:57
I have try that
CallManager(config-telephony)#transfer-pattern 55
CallManager(config-telephony)#call-forward pattern 56
On analog phone I call IP Phone 100 and now I want to transfer the call to the IP Phone 101 but on analog phone if I dial 56 or 55 or other nothing happens
p.maillot Mon, 12/22/2008 - 08:49
Sorry, I don't understand.
When you are on an anolog phone how to transfer a call to an another extension?
Nicholas Matthews Mon, 12/22/2008 - 09:17
  • Red, 2250 points or more
That is in the document that I sent. You have to register that port with SCCP, and then you have to set up feature codes where you dial *2 and then the number, and things like that.
It's quite a bit of configuration. I suggest reading through the links I sent.
p.maillot Mon, 12/22/2008 - 10:27
I have put
Router(config)#stcapp feature access-code
Router#sh stcapp feature codes
prefix **
call forward all **1
call forward cancel **2
pickup local group **3
pickup different group **4
pickup direct **6
stcapp feature speed-dial disabled
Maybe I have forgot something? But when I dial **1 to tranfer a call nothing it happens.
Nicholas Matthews Mon, 12/22/2008 - 11:30
Yes, you need the entire sccp configuration.
It will look like:
sccp
sccp ccm group 1
ass ccm 1 pri 1
p.maillot Tue, 12/23/2008 - 00:19
I have always the same problem, I want to transfer a call from my analog phone but when I dial feature access-code key on my analog keyboad nothing it happens,maybe I have do somting wrong?
See my conf
My FXS phone is on port 0/1/0
stcapp ccm-group 1
stcapp
prefix *#
call forward all 2
call forward cancel 9
voice-port 0/1/0
caller-id enable
sccp local GigabitEthernet0/1
sccp ccm 192.168.0.13 identifier 2
sccp ccm 192.168.0.12 identifier 1
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate ccm 2 priority 2
dial-peer voice 76 pots
destination-pattern 250
port 0/1/0
dial-peer voice 78 pots
service stcapp
port 0/1/0
Nicholas Matthews Tue, 12/23/2008 - 10:13
check 'show sccp' to see if the analog port is registered
p.maillot Tue, 12/23/2008 - 22:43
CallManager#sh sccp
SCCP Admin State: UP
Gateway IP Address: 192.168.0.1, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.0.12, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 1
Call Manager: 192.168.0.13, Port Number: 2000
Priority: N/A, Version: 3.1, Identifier: 2
Alg_Phone Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Device Name: AN2255E60821080
Reported Max Streams: 1, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 20
Supported Codec: g711alaw, Maximum Packetization Period: 20
Supported Codec: g729r8, Maximum Packetization Period: 220
Supported Codec: g729ar8, Maximum Packetization Period: 220
Supported Codec: g729br8, Maximum Packetization Period: 220
Nicholas Matthews Wed, 12/24/2008 - 05:46
It's not registered. You will need to go back and check your sccp configuration, as well as your CME configuration.
hth,
nick
