Call blocking
Dec 22nd, 2008
With this command
dial-peer voice 1 pots
destination-pattern 0
port 0/3/0
forward-digits 1
With this config all extension can take this line by dial the 0.
How to authorize only a range of extension or only a specific extension to take this line?
hassan_oudeh Mon, 12/22/2008 - 04:00
ok then you need to do COR list configuration,
for example:
you have these two phones:
ephone 1
button 1:1
cor incoming phone1
ephone 2
button 2:2
cor incoming phone2
COR config:
dial-peer cor custom
name phone1
name phone2
dial-peer cor list phone1
member phone1
dial-peer cor list phone2
member phone2
then on that dial-peer
dial-peer voice 10 pots
forward 1
port 0/3/0
cor outgoing phone2 <-- will enable only phone2 to call this number
refer to this link for more inforamtion:
please HTH if usefull
p.maillot Thu, 12/25/2008 - 02:26
Thank, now I can block the "0" for a specific extension or some extension but I want to do that.
I want by dial "0" that the extension 100 can call all number begining by 2xxxxxxx and 3xxxxxxx and I want that the extension 101 can dial only 3xxxxxxx and no 2xxxxxxx numbers.
