6500 PFC3B not collecting NetFlow stats for software-routed flows
Can anybody explain, should the 6500 collect NetFlow statistics for flows routed in software? The problem is that when I send 1000-packet ping I do see the statistics collected, but when I send the ping with Record Route IP option NetFlow counters are all zero... (The flow _is_ created as a hardware-switched PFC flow...).
The IOS is 12.2(33)SXH2a on Sup720/PFC3b.
Po2 172.16.54.254 Vl1 172.30.1.11 01 0008 0000 1000
Vl1 172.30.1.11 Po2 172.16.54.254 01 0000 0000 1000
Po2 172.16.54.254 Vl1 172.30.1.11 01 0008 0000 0
Vl1 172.30.1.11 Po2 172.16.54.254 01 0000 0000 0
mls aging long 64
mls aging normal 32
ip flow-cache timeout inactive 30
ip flow-cache timeout active 1
mls netflow usage notify 60 120
mls flow ip interface-full
mls netflow interface
mls nde sender version 5
ip flow-export version 5
ip flow-export destination 172.30.1.99 3000
interface Port-channel1
ip address 172.16.0.6 255.255.255.252
ip flow ingress
interface Port-channel2
ip address 172.16.0.14 255.255.255.252
ip flow ingress
interface Vlan1
ip address 172.30.1.101 255.255.255.0
ip flow ingress
arp timeout 300
