Creating a conditional configuration template
Dec 22nd, 2008
Hello
how can I create a configuration template that can be applied on a large number of devices in such a way that if a certain configuration is found on a device , a certain command is applied on that devices and I'm taking about creating around 50 different conditions.
Best regards
Joe Clarke Mon, 12/22/2008 - 06:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Are you asking about a specific application (e.g. Resource Manager Essentials)?
oalvi Wed, 12/24/2008 - 03:36
I'm Using Cisco Works LMS 2.6
Joe Clarke Wed, 12/24/2008 - 08:04
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You might be able to use Baseline Compliance to achieve what you want, but you will need to be more specific about the conditions. The RME 4.0 baseline feature is more limited when compared to 4.1 and higher. So while certain conditions will be possible, conditional interface configurations (for example) will not be.
