Danilo Dy Mon, 12/22/2008 - 03:13
  • Blue, 1500 points or more
2 possible reasons.
1. You plugged NM-8AM. For 3800 Routers, you need NM-8AM-V2.
2. Not compatible with the feature in your router bundle. i.e. IOS and/or VPN Module
I think you hit item 1 since your "show diag" shows the NM-8AM module that you plugged is "Hardware revision 1.0"
omar.elmohri Tue, 12/23/2008 - 01:14
I have 2:
one NM-8AM-V2
and one NM-8AM
You mean that the second one is not compatible?
Correct Answer
Danilo Dy Tue, 12/23/2008 - 02:28
Yes, NM-8AM is not compatible.
