reserve bandwidth for particular destination ip.
Dec 22nd, 2008
users in my office access a particular
ip which is in the other loaction for which they want the bandwidth of 512kbps to be reserve from 2mb link can you please help me to know how to do this?
Joseph W. Doherty Mon, 12/22/2008 - 04:14
What type of WAN topology technology? (I.e. Internet, point-to-point, frame-relay, MPLS, etc.?) Do you control all network devices? What type of network devices?
Joseph W. Doherty Mon, 12/22/2008 - 05:30
On many Cisco routers, if CBWFQ is supported, you can map a class to the IP address of interest and reserve your 512 Kbps. If you're just doing logically point-to-point across MPLS, that would be enough. If, however, you're supporting multiple sites and allow any-to-any, you often encounter MPLS egress congestion. Since you don't control the MPLS egress router, your MPLS provider does, you'll need to discuss your requirement with your MPLS provider.
Many MPLS providers can offer QoS. You mark your traffic going into MPLS a certain way, and they can provide some guarantee of egress bandwidth, e.g. they might guarantee a certain class will obtain 25% of your link, which if its a 2 Mbps link will provide your 512 Kbps.
archari Mon, 12/22/2008 - 11:13
1st make an ACL to match your destination ip
access-list 101 permit ip any host x.x.x.x
2nd make a class map to match the ACL
class-map myfavdestination
match access-group 101
3rd make a policy-map to match the class above with the QoS you want to give it
policy-map reserve512
class myfavdestination
bandwidth 512
4th attach the policy-map to the outgoing interface pointing to the SP
interface serial x/y
service-policy output reserve512
verify using "show policy-map interface serial x/y" if the class is being given the appropriate QoS levels.
Note: This is only a barebone config and you might need to work with your provider closely to set DSCP values if necessary to get the required levels
